Resistance reading on each zone
  • Replies 38
  • Views 9k
  • datadiffusion
    datadiffusion
    20 years ago might have had a chance, now the distinction between and alarm and a 'home automation' system would keep the courts busy for years...   The ultimate test of 'is it an alarm you'
  • Surely one of your team of experienced cctv specialists who do insurance approved installations would be best placed to explain this stuff to you face to face?
Well then why it's not showing anything when measuring simple 2k2 resistor? Anyway I'll test on other multimeter on Monday will see but I think it's faulty.
This is where a simple resistance check card can help to ensure your meter is doing what it's supposed to, and acclimatise you to using the meter correctly.
0 for resistance on manual range meters is likely to be Out of range. 1 will be open circuit, Infinite resistance.
unless your testing resistors then 200 ohms is the setting it should be in
