Flush contact grade 3 for aluminium door
  • Replies 30
  • Views 7.6k
  • PeterJames
    PeterJames
    Just because it has a high number (In comparison to G1 G2) its not necessarily the best, fitting G3 in many cases makes the system less reliable. G3 contacts are sided and are much less forgiving when
  • Not sure how this helps the OP ?
7 minutes ago, james.wilson said:
could you post pictures of the doors?
Edited by MrHappy
LOL @ MrHappy
I can't post pictures yet as I have just started building works and windows / doors have not been ordered yet. Is there any other info I can provide? Patio sliding door will be a standard 3 panel slider, fixed one end constructed in aluminium and double glazed. Side entry door will be outward opening aluminium door to replace current UPVC door. Main door is after a locked porch and is standard hardwood timber door. This will be main entry door.
Hope this helps!
Yep when it comes to flush I still rate elmdene better than Knight, who I use for everything else.
Yup
  • 1 month later...
cheers for the feedback!  Don't know if you've tried our G2 and G3 flush multi's recently, but we've now thinned the fixing plates down to 1mm after installer input.
