johnwestsussex Posted September 25, 2016 Share Posted September 25, 2016 we had a power cut for more than 20 hours. since we are unable to set the alarm. on the pcb the following message is "power o/p fault" what to do? do we have to change the battery? apparently our battery is a 12 volts is there any particular precaution to take while we change the battery. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40468-texecom-premier-power-op-fault/ Share on other sites More sharing options...
james.wilson Posted September 25, 2016 Share Posted September 25, 2016 Id expect that running on its battery for 20 hours it has gone completly flat and may have damaged it depending on its state to start with. I dont know that panel but lcd looks a bit dim. Id disconnect the battery to start with and meter your power outputs securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40468-texecom-premier-power-op-fault/#findComment-450519 Share on other sites More sharing options...
Nova-Security Posted September 25, 2016 Share Posted September 25, 2016 Have had one displaying that message and something else, needed a new switch mode power supply unit. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40468-texecom-premier-power-op-fault/#findComment-450533 Share on other sites More sharing options...
datadiffusion Posted September 25, 2016 Share Posted September 25, 2016 Assume faulty battery has gone very low ohms and is dragging down overall voltage to below 12V, causing a fault? So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40468-texecom-premier-power-op-fault/#findComment-450534 Share on other sites More sharing options...
MrHappy Posted September 25, 2016 Share Posted September 25, 2016 enter code, then enter code & press reset Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40468-texecom-premier-power-op-fault/#findComment-450535 Share on other sites More sharing options...
datadiffusion Posted September 25, 2016 Share Posted September 25, 2016 54 minutes ago, MrHappy said: enter code, then enter code & press reset Having changed battery I'd suggest! So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40468-texecom-premier-power-op-fault/#findComment-450536 Share on other sites More sharing options...
Rulland Posted September 25, 2016 Share Posted September 25, 2016 Seen this quite often on a site that is having building works/prone to sparks turning power on/off. As Mr H, Just a simple reset is required-hazard a guess at software glitch-possibly!. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40468-texecom-premier-power-op-fault/#findComment-450537 Share on other sites More sharing options...
MrHappy Posted September 25, 2016 Share Posted September 25, 2016 IIRC all the elites produce both "mains fail" & "power o/p" when the mains is off I'd guess its something to do with the 4 pin molex pin on the switch mode psu the switch mode psu is also a bit naff & much more likeley to fail compared to transformer 1 Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40468-texecom-premier-power-op-fault/#findComment-450538 Share on other sites More sharing options...
datadiffusion Posted September 26, 2016 Share Posted September 26, 2016 Its true there is so little to actually go wrong with a lump of metal, but plenty to go wrong with a bunch of Chinese silicone... So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40468-texecom-premier-power-op-fault/#findComment-450552 Share on other sites More sharing options...
Jim Randle Posted September 26, 2016 Share Posted September 26, 2016 We have had a few switched mode PSUs fail. Texecom say its due to mains problems but they should be more robust. Their Tech Support said that they have "Over Engineered" the PSUs to get round the problem. I don't know if they are installing them in all new panels though. Perhaps someone from Texecom will tell us. Adrian?. Jim Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40468-texecom-premier-power-op-fault/#findComment-450553 Share on other sites More sharing options...
