Is everyone quiet?
Too busy really.........just recently, stupidly so
based north west
not a bad thing I suppose, but plenty of 12 hr days and what not....
  • Replies 40
  • Views 9.1k
  • sixwheeledbeast
    sixwheeledbeast
    Adapt and Conquer, industry is fecked IMO.
  • A little bit more on topic than diesel engines,   Did a double take to see a shinney yale box on this -
  • 1.6hdi, been wiped but did'nt look much worse before...   Elm's a couple of quid & limited in its use, I've also a knock off lexia which I've not quite managed to get going
1
1 hour ago, WDT said:
Just a thought next time you are under there just check the allen bolts that hold the injector down are tight,
female torx on mine (2008) tweaking the circled one appeared to do the business...
Most the time when i see leaks on the main feed to the injectors it's very wet (Like Dripping wet )
amazed such a minor weep appears to have bought the lamp on
But back on topic, your quiet cos your working on the vans?
8 hours ago, MrHappy said:
1
Yep them ones,
This makes me cry, but its was the same when i was fitting car alarms in the late 90's we would be expected to fix cheap **** ( sparkrite) and they thought it would offer the same as our pro kits.
I went to a potential new customer recently after a burglary (Optima 2 plus system) to tell me the insurance company recomended Yale Smart alarm and gave them a short demo, the pad wasnt as swish as the one above mind.
Really, do you mean broker?
Graded?
The insurance assesor is what they said, not the broker which surprised me, have to take what customers say with a pinch of salt mind I wasnt there, but  defo the yale alarm system from the insurance assesor.
