"system Troubles" Message With Risco Agility 3
A couple of weeks ago we started getting a "System Troubles:" message on the keypad screen when attempting to set the Agility 3 alarm.
post-71242-0-53651900-1456092073_thumb.j
When this message appears it pretty much blocks the alarm from doing anything else. It can happen over and over again.
The alarm was installed last March/April 2015 and hasn't shown this problem until February 2016 -- and it stopped us being able to set the alarm on exit for a few days. Then all of a sudden the problem went away, luckily on a day it was really needed.
I read in the manual today that the troubles can be bypassed - but is it possible to retrospectively review what caused the troubles? All the times the message appears it was my other half setting the alarm and I wasn't present until the day it did work (typical!)
well it is risko. You are a bit stuck having the worst pro gear.
Ok so what do the troubles show, your user manual should show you how to list them or something , I don't this panel but won't be much different from a visonic lol
James you should know better, you don't like others posting ****, so why are you doing it ?
Check the system log and list what it shows so we can see your issues.
Valid point though. I'm not keen on the gear tho
really start to worry when its starts displaying "mooonlight" "love" & "romance" ?
