mountianrider Posted January 13, 2016 Share Posted January 13, 2016 Evening My customer wants a 8 channel 8 tb cvi dvr with 1080p cameras. I calculated this at 18 days @ 12 FPS with 1080 Res. My question is, what is the minimum frame rate you would drop to? Would you notice a diff recording @ 720p? Thanks Quote Link to comment Share on other sites More sharing options...
Lwillis Posted January 13, 2016 Share Posted January 13, 2016 What's the point in fitting 1080p and then recording at 720? We usually setup a schedule or motion recording to increase the time Is drop the FPS to about 8 tho that should be high enough for most situations Quote Link to comment Share on other sites More sharing options...
Adi Posted January 13, 2016 Share Posted January 13, 2016 As above dont drop the res. 6 fps is ok to, just depends on fast moving objects close to the camera. Quote I really can't be ar**** with it anymore. Link to comment Share on other sites More sharing options...
PeterJames Posted January 13, 2016 Share Posted January 13, 2016 We have motion detect on with 5 fps with pre motion and 8 on full motion, the recorder is recording all the time but saves 10 secs pre motion @5fps and then jumps to 8fps Quote Link to comment Share on other sites More sharing options...
mountianrider Posted January 14, 2016 Author Share Posted January 14, 2016 Interesting so 6FPS is ok? Even though real time is 25? Why is there options for 60 FPS? Quote Link to comment Share on other sites More sharing options...
9651 Posted January 14, 2016 Share Posted January 14, 2016 (edited) I try and aim for around 12ish Less is more noticeable to the eye Edited January 14, 2016 by 9651 Quote Link to comment Share on other sites More sharing options...
Adi Posted January 14, 2016 Share Posted January 14, 2016 no its not. Quote I really can't be ar**** with it anymore. Link to comment Share on other sites More sharing options...
jnealon Posted January 15, 2016 Share Posted January 15, 2016 I usually don't go below 6 fps, its more than enough. I know some installers who insist on going the full 25 fps, unless your making "movies" it makes no sense. Quote www.realsecurity.ie Link to comment Share on other sites More sharing options...
james.wilson Posted January 15, 2016 Share Posted January 15, 2016 I usually don't go below 6 fps, its more than enough. I know some installers who insist on going the full 25 fps, unless your making "movies" it makes no sense. Qfa Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
petrolhead Posted January 15, 2016 Share Posted January 15, 2016 For me, normal, vbr, highest, 1296kbps max, 6fps Event(motion or pir) change to 12fps 3192kbps or 2048 depending on storage. Quote Link to comment Share on other sites More sharing options...
