Optima 2 Plus Alarm
whitenotred
Hi All,
This is my first post and hopefully I have picked a topic relevant to my question.
When I moved into my house 18 years ago the Optima 2 Plus alarm was already fitted, so no idea how old it is !
Generally it works fine, if you don't mis-key and end up with 'odd' settings, but my problem relates to battery backup.
Occasionally we get power outages - which causes the alarm to sound constantly. I have been told the battery backup may not be working ?
On other forums there is talk of a battery in the control panel - if this is the keypad then I can't see a battery.
Is the control panel the white box in my garage ? If so, again from other forums, it looks like the battery I need to replace is large and expensive ?
Can anyone confirm that I do indeed need to replace my battery in the 'white box' and, if so, how (without driving the neighbours to distraction !).
Man thanks in advance !
[Moved - please don't bump 10 year old topics]
Edited by datadiffusion
Not related to 10 year old keypad topic
Would you be happy using an 18+ year old fridge, microwave, computer, toaster, etc...?
Would you keep a car for 18 years having never serviced it once?
Is your central heating boiler 20 years old?
I would say yes the battery is long dead, your neighbours must love you for that, but I would suggest a newer system for the most
expensive asset you own.
I was speaking to a chap today that's refurbing his house (about unrelated stuff), he's spent tens of thousands on a build that totally revolves around AV and it's a really top notch job, back to the brick so he can stand off the plaster board to accommodate wiring etc. I commented on his R8 RKP and he seriously said he only spent money on things that mattered...
Edited by norman
I will keep quite about my boiler due to its age but i know it needs doing but it is service every year by a engineer who is probley younger then the boiler :shy:
Does the optima plus only do the down stairs and maybe not even the garage door. if its that old i bet even the bell box looks old. :- just saying.
I would go for a upgrade :thumbsup:
