Eurosec Cpx Fuse/bat. Fault On Every Hour
Legin76
Hi Fuse/bat. Fault On Eurosec Cpx. I've checked all the fuses and they appear to be ok so I think it needs a new battery. The current one has been there a long time.
The issue I'm having is that every hour, on the hour the internal sounder goes off day and night with the Fuse/bat. Fault message. I've got an engineer coming on Tuesday but until then I can't have it going off all the time. Is there a way I can stop or silence it? I have the engineers manual and code but can't work out what I need to do.
Edited by Legin76
The installer has programmed this feature, I would advise not to touch the panel until the engineer calls to change the battery. Isn't there an engineer who can call today or tomorrow ? Tuesday is not good enough. Do you have a copy of the user instructions ?
like lwillis says,its money for nowt and you have your foot in the door for a contract (if its decent) or an upgrade,most just want the noise stopped be it a batt change or just power the thing down in and out in 15 mins for ££
