Honeywell Informa Speech Dialler - Not Dialling All Of A Sudden?
13 hours ago, al-yeti said:
Dialler is so simple never had these issues
Only seen a speaker drive fail
Hi.... I have got it working .  I agree it was unlikely to be faulty and it was defying logic..... that logic being mine, twisted and probably wrong, in what I was observing and deducing from it.....   working on the premise it was the INT dialler circuit not triggering the going-high or going-low voltage transition, I was going to make use of the PA or FIRE inputs on the dialler (i.e. INT output from alarm to FIRE input of dialler).... and set about first testing this .....  measuring the alarm outputs I could see that they were normally HIGH and went LOW when active/triggered... what I noticed was that when I put the alarm in test mode and activated "FIRE" (falling voltage) it did NOT dial, but,, a minute later when de-activating that output (voltage going high, rising) it dialled.... aha.... so I must have interpreted the settings [4] incorrect.   I set all these to be "ON" (illuminated) and now all 3 test alarm outputs give a correct dialler response ( and it dials me! ), yay.    (I had tried all this last night I thought but maybe just got in a muddle with all the tests I did!)
So..... it could have been me being thick, or, just tired and frustrated with it last night !!!  it now tests out fine, and, I have a cunning plan if indeed that INT circuit on the dialler is intermittently not behaving itself..... [can't think of a reason this wouldnt work, it's just 3 similar alarm outputs and 3 similar dialler inputs, labelled for sanity when setting up specific voice messages for each one....
Thanks all......   if nothing else this thread gave me some re-assurance and hope and encouragement to not give up (which to be honest was also  due to the hefty price tag of a replacement)
  • 6 months later...
  • Replies 40
  • Views 30.4k
So. this old chestnut has reared its head again.
Due to an accidental activation, it revealed that the dialler is again not working properly. The device itself seems to be perfectly fine; it dials, plays the message etc etc but a call is not received. The only thing that has changed in the past two or three weeks is that we have changed our internet provider and in so doing also upgraded to a fibre connection.
Any ideas what could be the problem now?
Tom.
Tom.
Shouldn't be a problem , but I would say when you switched to fibre the socket it's connected to might be disconnected
Manually check you have dialtone with a phone
The informa will still dial without dial tone
When it dials you hear the dialling on the speaker , but you should hear the dialtone to
this is why diallers imho shouldn't be used for alarm notification. You never know if it's gonna work when its needed as its not polled.
but as al says check you can use a conventional pstn phone
All down to risk, a dialer should be set up to send a test signal imo but that usually adds cost.
I agree also signalling line fault at the controls helps, but not infallible due to only testing line voltage and not polling the line regularly.
I think I know what the problem is.
Prior to the change over the old modem and the phone connected to the main phone line via a filter, and the phone would work when the modem was switched off. Now, however, the setup is different and the phone is plugged into the modem
Therefore, I'm thinking that I also need to have the dialler plugged into the secondary telephone socket on the new modem. Does that seem correct?
Old setup with filter behind sockets:
New setup with telephone connected to 'Line 1':
So to test this I want to use a bunch of phone extensions to make an adhoc connection between the dialler and the modem to test for function before I go trying to feed wires though the walls/floor. The question is, out of a four wire telephone cable, which two are carrying the signal or which contacts of the RJ plug are being used; centre contacts, outers etc?
Cheers,
Tom.
Just looked at the photo and saw that the Line 1 & 2 connections of the modem only have two contacts per socket, the centre contacts, so not to worry about that as I can easily use my multimeter to figure out which wire, in the photo above, goes to which contact.
Tom.
Al-yeti,
Going back to your questions. Yes, it dials the tel number and thinking about it now there is no dial tone for the dialler.
The phone works fine.
Tom.
Edited by Tommygunn
