Honeywell Informa Speech Dialler - Not Dialling All Of A Sudden?
I have a Honeywell Accenta G4 and HW Informa Speech Dialler which I installed about a year and half ago. Installed without a hitch.
However, when I accidentally tripped the alarm last night I discovered that the Informer Speech Dialler did not ring my phone or any of the other phones nominated. Not only did it not dial, it simply did not activate.
Up until last night, whenever it has been required to work or tested, it has worked perfectly.
Nothing has been touched to cause this.
The only thing that has happened, in the past few weeks, is that we have transfered to a new internet/phone provider who also gave us a new modem/router to use.
Today, I have been running tests on the dialler and everything functions as it should, test mode, messages etc, except that when it dials and plays the message you can hear what sounds like an engaged tone in tandem with the message.
For your info I'm in Italy, previously with Infostrada and now with Fastweb, using a UK Informa Dialler.
Any ideas?
Tom.
  • Replies 40
  • Views 29.9k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
You said " Today, I have been running tests on the dialler and everything functions as it should"
But you also say its doesnt dial out on alarm?
So to me it sounds as if there is no dial tone on the informa or it isnt seeing the dial tone, i assume your phone is a standard phone? or is it an ip phone connected to the router? which might make sense why that wil still work, if thats the case what happens if you plug in a standard phone
might be wrong but inof didnt add up above unless i read it wrong
doesnt help with an answer but this is why unmonitored comm units are a bad idea. you need to know it will report when its needed.
who cares it's free!
side point is your new provider restricting your calls ie incoming only hence wont actually dial out to anything? so you might to check that
al-yeti,
By tests I meant that such things as a test dial out, change of nominated telephone numbers etc all functioned correctly. Basically, there appears to be nothing wrong with the dialler itself and I don't think there is.
The only thing that is wrong is after it dials it gives out an engaged tone while the message plays out.
Our phone line is independent of the modem/router.
I've even gone to the extent of turning off the modem, disconnecting all coms cables to the modem and landline phone and then making test calls from the dialler to my wife's mobile and a known working landline number. I get exactly the same result.
The three default numbers I have entered on the dialler are firstly my mobile, my wife's mobile and lastly my brother in law's. Never been a problem in the past with both alarm conditions and test calls contacting the mobiles in order without a problem.
As you can see from the above test, the problem is not restricted to just mobiles but landlines as well.
No restrictions from our provider which I would have thought would be proved by the inability to dial a landline number.
Tom.
Edited by Tommygunn
So basically the informa calls you when the alarm activates and works with the addition of a beep or extra tone in tandem with message
I assume you tried deleting and recording new messages again? Incase that is corrupt somehow?
I got confused because of title ie "not dialling"
Out of desperation I opened up the panel where the landline enters the house and disconnected the cable from the rest of the house, house phone or modem completely disconnected. I then connected the landline directly to the dialler and still no luck!
I have also done a 'Non Volatile Memory' reset, which has had no effect.
Can I conclude that it must be something the new provider has done? Is this feasable since they actually don't physically do anything to the telecom networ?
Tom.
Still no luck with what? I thought it was dialling and calling you with only problem being the tone in tandem
Question, does it ring your mobile? The informa , if yes no need to open the main panel, it has to be the dialled
Question, do you mean the informa is "dialling" but you mean tries to dial and as it does so the engaged tone comes up?
The informa starts playing the message as soon as it starts dialling that's normal for it
So same question when you say it dials, does it actually get your mobile to ring? If not then as I said before your getting an engaged tone when informa is dialling out and has to be to do with the line
Ok I think reading over you mean the informa performs the dialling operations but does NOT actually dial out because the line is not allowing you to dial out, engaged tone means line restrict for some reason
Inability to dial landline numbers means your line is restricted to incmoning only, please read over this thread again
First things first. Hook up a phone on the line and rail the numbers yourself.
Does that work first.
Does the line need a pause at the beginning to allow a rail tone.
Had this before where the unit is dailing out before the line is ready.
Try this first and let us know
Edit
Dial not rail
Edited by kwc
