Roller Shutter 1 Or 2 Contacts?
progear
Its my own garage door, Ive just taken the picture to give an example of the bracket. And yes I'll swap the rsc the minute I can be arsed.
Originally said by Charles Babbage
On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
So here's a senareo recently and a warehouse with a row of sky lights. An ax 70 would have been ideal to mount high up to supplement the detection on ground floor. Couldn't fit any as not graded, is this correct?
dont forget to re-enable the circuit when you do
only at g3
id move the mag up and put the contact underneath too
Valid point, but I think the rsc is as close to the edge of the concrete as I was comfortable drilling with an SDS drill. Whats left of the floor paint shows the end of the level concrete after that it slopes off and gets thin. The bracket means the rsc doesnt need to be so close to the door.
