Texacom Premier Com 1 Lead
Hi Guys.
Has anyone tried to make the serial Com 1 Lead on the Premier Panel to connect from panel to usb port? I take it that this will be a normal serial RS232 to USB? Thanks in advance
49 minutes ago, shabir said:
Hi Guys.
Is it worth it? If maybe your enthusiastic maybe, but easier to buy one
Althought @Galaxy Guy probably has made loads of different types
Thank Al-Yeti for response. I had a spare RSS Galaxy lead kicking around and wanted to utilise it to suit. The com port connectors are identical. just needed to check if it was do able...
Your our experiment then , try it
Although I thought that lead wouldn't work on different panels
they may look identical but the pin layout may be different check this first, o think there is power on the port
Thanks James....I just did some research and you are right, there is a 12v pin. Im just after the TX RX and Gnd (Not the 12v)so hopefully shall be good.....
