Morganator190 Posted July 16, 2025 Share Posted July 16, 2025 Hi hope you can help, ive worked on alarms previously. I suspect our alarm is engineer code changed and locked. On inspection of the pcb board, the main IC chip looks socketed. Is it possible to dump the chip, change the engineers code and re flash back, retaining user and aux settings? If not, is it possible to keep all PIR, door contacts etc and install a new unit instead? Here are some photos of the current installed alarm. Its suspected to be installed 10 years ago, i believe the company has gone out of business and would prefer to setup and control my alarm system. Its currently got issues where one of the door contacts failed and after replacing the alarm won't accept it. After 2 years of the alarm not been set it randomly goes off, suspecting fuse or battery issues. So ive disconnected all power to the unit until i figure out what to do next. Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47347-help-with-re-flashing-or-replacing-unit-not-sure-on-exact-model/ Share on other sites More sharing options...
al-yeti Posted July 16, 2025 Share Posted July 16, 2025 51 minutes ago, Morganator190 said: Hi hope you can help, ive worked on alarms previously. I suspect our alarm is engineer code changed and locked. On inspection of the pcb board, the main IC chip looks socketed. Is it possible to dump the chip, change the engineers code and re flash back, retaining user and aux settings? If not, is it possible to keep all PIR, door contacts etc and install a new unit instead? Here are some photos of the current installed alarm. Its suspected to be installed 10 years ago, i believe the company has gone out of business and would prefer to setup and control my alarm system. Its currently got issues where one of the door contacts failed and after replacing the alarm won't accept it. After 2 years of the alarm not been set it randomly goes off, suspecting fuse or battery issues. So ive disconnected all power to the unit until i figure out what to do next. Thanks If wiring is good, just change panel and keypad and probably bell and probably some detectors You will end up eventually changing it all lol Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47347-help-with-re-flashing-or-replacing-unit-not-sure-on-exact-model/#findComment-530465 Share on other sites More sharing options...
MrHappy Posted July 16, 2025 Share Posted July 16, 2025 (edited) Options - CPX from Ebay 595 / 600 + Keypad from ebay or replace everything... Edited July 16, 2025 by MrHappy Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47347-help-with-re-flashing-or-replacing-unit-not-sure-on-exact-model/#findComment-530467 Share on other sites More sharing options...
sixwheeledbeast Posted July 16, 2025 Share Posted July 16, 2025 I'd get rid, flaky Risco stuff. But yes it's totally wireless detection so replace devices too. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47347-help-with-re-flashing-or-replacing-unit-not-sure-on-exact-model/#findComment-530469 Share on other sites More sharing options...
MrHappy Posted July 16, 2025 Share Posted July 16, 2025 39 minutes ago, sixwheeledbeast said: I'd get rid, flaky Risco stuff. I had a bloke not bat an eye lid at replacing a number of 2yr old WiFi access points Asking to replace a 20yr alarms is like I've shat on the floor 1 Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47347-help-with-re-flashing-or-replacing-unit-not-sure-on-exact-model/#findComment-530470 Share on other sites More sharing options...
Morganator190 Posted July 19, 2025 Author Share Posted July 19, 2025 On 16/07/2025 at 10:02, MrHappy said: Options - CPX from Ebay 595 / 600 + Keypad from ebay or replace everything... Thanks if i replace everything. What would recommend for a wireless expandable, monitor solution? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47347-help-with-re-flashing-or-replacing-unit-not-sure-on-exact-model/#findComment-530488 Share on other sites More sharing options...
Morganator190 Posted July 19, 2025 Author Share Posted July 19, 2025 On 16/07/2025 at 02:05, al-yeti said: If wiring is good, just change panel and keypad and probably bell and probably some detectors You will end up eventually changing it all lol Thanks how could you test if wireing is good? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47347-help-with-re-flashing-or-replacing-unit-not-sure-on-exact-model/#findComment-530489 Share on other sites More sharing options...
PeterJames Posted July 19, 2025 Share Posted July 19, 2025 2 hours ago, Morganator190 said: Thanks how could you test if wireing is good? The wiring is only going to the bell, keypad, and wireless expander. If you have a multimeter and know how to use it then testing if the wiring is good is simple. But the fact that you have to ask how would say to me that you dont. I wouldnt advise replacing the panel over reviving the old Gardtec stuff, its obsolete for a reason. As the panel and detection is all wireless, the best solution is to replace it with similar. You could DIY it if you are feeling brave enough (what could possibly go wrong?) . Or you could get a company in to do it properly for you. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47347-help-with-re-flashing-or-replacing-unit-not-sure-on-exact-model/#findComment-530490 Share on other sites More sharing options...
Morganator190 Posted July 21, 2025 Author Share Posted July 21, 2025 Thank you for that. Any recommendations on what system to replace it with? Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47347-help-with-re-flashing-or-replacing-unit-not-sure-on-exact-model/#findComment-530496 Share on other sites More sharing options...
MrHappy Posted July 21, 2025 Share Posted July 21, 2025 I'd assume app rather then monitor ? I'd probably use a Orisec CP20 + The Keypad with the big display, wireless access point on the panel, orsiec radio devices & pyronix deltabell Or a Texecom 64-w + blue lcdp + radio devices, smartcom + deltabell Or a euro 76, radio zem, wireless wifi card, euro keypad, euro radio devices & a deltabell Orisec is probably cheapest equipment cost & euro the dearest, Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47347-help-with-re-flashing-or-replacing-unit-not-sure-on-exact-model/#findComment-530497 Share on other sites More sharing options...
