Help with re flashing or replacing unit not sure on exact model
Hi hope you can help, ive worked on alarms previously. I suspect our alarm is engineer code changed and locked.  On inspection of the pcb board, the main IC chip looks socketed.  Is it possible to dump the chip, change the engineers code and re flash back, retaining user and aux settings?
If not, is it possible to keep all PIR, door contacts etc and install a new unit instead?  Here are some photos of the current installed alarm.  Its suspected to be installed 10 years ago, i believe the company has gone out of business and would prefer to setup and control my alarm system.  Its currently got issues where one of the door contacts failed and after replacing the alarm won't accept it.  After 2 years of the alarm not been set it randomly goes off, suspecting fuse or battery issues.  So ive disconnected all power to the unit until i figure out what to do next.  Thanks    a96affbd-7de5-46d2-b502-04f2b4aa2783.thumb.jpg.bcf264bbf122e9998fa83911123e6959.jpg
If wiring is good, just change panel and keypad and probably bell and probably some detectors
You will end up eventually changing it all lol
Options -
CPX from Ebay
595 / 600 + Keypad from ebay
 or replace everything...
Edited by MrHappy
39 minutes ago, sixwheeledbeast said:
I'd get rid, flaky Risco stuff.
I had a bloke not bat an eye lid at replacing a number of 2yr old WiFi access points
Asking to replace a 20yr alarms is like I've shat on the floor
On 16/07/2025 at 10:02, MrHappy said:
Options -
CPX from Ebay
Thanks if i replace everything. What would recommend for a wireless expandable, monitor solution?
Thanks how could you test if wireing is good?
The wiring is only going to the bell, keypad, and wireless expander. If you have a multimeter and know how to use it then testing if the wiring is good is simple. But the fact that you have to ask how would say to me that you dont.
I wouldnt advise replacing the panel over reviving the old Gardtec stuff, its obsolete for a reason.
As the panel and detection is all wireless, the best solution is to replace it with similar. You could DIY it if you are feeling brave enough (what could possibly go wrong?) . Or you could get a company in to do it properly for you.
I'd assume app rather then monitor ?
I'd probably use a Orisec CP20 + The Keypad with the big display, wireless access point on the panel, orsiec radio devices & pyronix deltabell
Or a Texecom  64-w + blue lcdp + radio devices, smartcom + deltabell
Or a euro 76, radio zem, wireless wifi card, euro keypad, euro radio devices & a deltabell
Orisec is probably cheapest equipment cost & euro the dearest,
