Ryan Godfrey
I have a stand alone KP500 only attached to an electric strike lock
the com NC
the key pad is giving the lock power, locking it
i have programmed it, with fobs and a code
when i swipe the fob or enter the code , the keypad flashes green and accepts it however the power does not drop for the lock
the lock will of course open it I take the power off manually taking a cable out
Not used one.
Is the strike time really short?
Does the strike lock require the same voltage as the KP?
Have you tested your findings with a multimeter?
Is it just not wired correctly or some other simple mistake?
2 minutes ago, sixwheeledbeast said:
is the strike time really short?
That would be my guess. but as factory standard the timer is usually too long.
Have you put the com and n/c in series with the lock and power? I know its a daft question but I have no idea of your ability
the com NC
Guessing myself
Right led flashes?
What's left led doing ? Red or green
Is it in secure or insecure mode , as I thought one mode requires both fob and code in some sequence
