guyfingers Posted January 8, 2025 Share Posted January 8, 2025 Hi all Newbie here. I moved into a house which has a working Visonic PowerMaxComplete burglar alarm system with 4 PIRs, external alarm, 2 remote fobs and door sensor. A few weeks back, a surge knocked out a load of appliances, including the transformer in the alarm. Needless to say, running on the internal battery, it ran out of juice and has been dead since the transformer was replaced, It's now up and working, but my code isn't being accepted - neither is 1111 or 9999. Strange, as the fobs are working and also the door sensor. Hope it doesn't mean I'll have to do a hard reset and re-program everything TIA Guy Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47086-visonic-powermaxcomplete-code-suddenly-changed/ Share on other sites More sharing options...
PeterJames Posted January 8, 2025 Share Posted January 8, 2025 53 minutes ago, guyfingers said: Hi all Newbie here. I moved into a house which has a working Visonic PowerMaxComplete burglar alarm system with 4 PIRs, external alarm, 2 remote fobs and door sensor. A few weeks back, a surge knocked out a load of appliances, including the transformer in the alarm. Needless to say, running on the internal battery, it ran out of juice and has been dead since the transformer was replaced, It's now up and working, but my code isn't being accepted - neither is 1111 or 9999. Strange, as the fobs are working and also the door sensor. Hope it doesn't mean I'll have to do a hard reset and re-program everything TIA Guy That is quite bizarre panels have a Non Volatile Memory (NVM) so they normally dont lose their programming when the power is completely lost. It could be that the default codes process was activated when you powered the system back up. Not sure what the default code for the powermax would be but its normally something like 1234, 4567, 7890, 0123, 2222, ect you could run through each one to see if any of them work. Keep your fob to hand because two many wrong codes will cause tampers Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47086-visonic-powermaxcomplete-code-suddenly-changed/#findComment-527376 Share on other sites More sharing options...
guyfingers Posted January 8, 2025 Author Share Posted January 8, 2025 Hey, thanks for your quick reply. Yes, it's strange that all the other items are programmed in correctly. The manual says user is 1111 and maintenance is 9999. I've tried both. Neither work I'm now beginning to think I changed it (bad memory), but have tried all my usual PINs but none has worked and it locks up for about a minute after 3 tries. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47086-visonic-powermaxcomplete-code-suddenly-changed/#findComment-527378 Share on other sites More sharing options...
james.wilson Posted January 8, 2025 Share Posted January 8, 2025 you should always chnage default codes. So id assume you did securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47086-visonic-powermaxcomplete-code-suddenly-changed/#findComment-527379 Share on other sites More sharing options...
guyfingers Posted January 9, 2025 Author Share Posted January 9, 2025 5 hours ago, james.wilson said: you should always change default codes. So id assume you did I'm afraid not - it was the day after our wedding anniversary so we kept it. I've just gone going to Installer mode - tried 8888, 9999, 1111 and 0000 - no joy (also tried 0123, 5678 and 7890) This is mad... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47086-visonic-powermaxcomplete-code-suddenly-changed/#findComment-527383 Share on other sites More sharing options...
al-yeti Posted January 9, 2025 Share Posted January 9, 2025 1 hour ago, guyfingers said: I'm afraid not - it was the day after our wedding anniversary so we kept it. I've just gone going to Installer mode - tried 8888, 9999, 1111 and 0000 - no joy (also tried 0123, 5678 and 7890) This is mad... You never had codes in first place then lol. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47086-visonic-powermaxcomplete-code-suddenly-changed/#findComment-527384 Share on other sites More sharing options...
sixwheeledbeast Posted January 9, 2025 Share Posted January 9, 2025 I'd say someone tried the code defaulting procedure and got it wrong or the panel is knackered. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47086-visonic-powermaxcomplete-code-suddenly-changed/#findComment-527389 Share on other sites More sharing options...
guyfingers Posted January 9, 2025 Author Share Posted January 9, 2025 10 hours ago, al-yeti said: You never had codes in first place then lol. Apparently when it's first installed, they use 9999 or 8888 and then have to change it. Maybe I'll try to find the people that first installed it (a million years ago!) - you never know! 3 hours ago, sixwheeledbeast said: I'd say someone tried the code defaulting procedure and got it wrong or the panel is knackered. I think the latter might be right... It beeps but you don't know if pressing the 0 really does enter 0 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47086-visonic-powermaxcomplete-code-suddenly-changed/#findComment-527396 Share on other sites More sharing options...
guyfingers Posted January 9, 2025 Author Share Posted January 9, 2025 I've bitten the bullet and going to pay for KAT to come over and sort it out. I've spent too much time on it already! Thanks for your help and advice, all. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47086-visonic-powermaxcomplete-code-suddenly-changed/#findComment-527397 Share on other sites More sharing options...
james.wilson Posted January 10, 2025 Share Posted January 10, 2025 Kat? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47086-visonic-powermaxcomplete-code-suddenly-changed/#findComment-527420 Share on other sites More sharing options...
