a_dad Posted November 10, 2024 Author Share Posted November 10, 2024 I now have 8 of Q20s and 100m shielded 8 core. I have one cable in. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46978-play-with-some-real-kit-on-my-kitchen-table/page/2/#findComment-526358 Share on other sites More sharing options...
sixwheeledbeast Posted November 10, 2024 Share Posted November 10, 2024 Shielded is unnecessary for Texecom, as long as it's Cable Type 2 or above that's fine. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46978-play-with-some-real-kit-on-my-kitchen-table/page/2/#findComment-526359 Share on other sites More sharing options...
a_dad Posted November 10, 2024 Author Share Posted November 10, 2024 Oh thanks. I picked it since some legs will run past/near/briefly alongside mains cable. Reading about, I am getting location is key to minimising false positives. It can be tricky, however, to find a corner that is not pointing at windows, not pointing at hot things (stoves/ kettles) and not directly over radiators. My Rads are now heat pump rads, so seldom get to 48, usually upper limit is 40. Which is worse, over a rad, pointing at a rad, pointing at a window, or pointing at a stove/kettle? My front windows overlook my lightly trafficked road, if passing cars are an issue. My rads really are pretty luke-warm when on. (They are pretty good at heating, though, since they are giant and have a high water flow rate). Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46978-play-with-some-real-kit-on-my-kitchen-table/page/2/#findComment-526360 Share on other sites More sharing options...
sixwheeledbeast Posted November 10, 2024 Share Posted November 10, 2024 This is were experience from people that fit and design stuff is worth it's weight for letting them do it. There is rarely a truly perfect corner so things have to be balanced. There are other things too, like accessibility to both work/maintain it and initially install the cabling. If the sensor maybe blocked in the future by tall furniture or curtains. Passive IR will not penetrate surfaces so cars are no problem. Definitely not above a heat source. The stove/kettle most likely off if going out, unless you have an Aga type setup. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46978-play-with-some-real-kit-on-my-kitchen-table/page/2/#findComment-526361 Share on other sites More sharing options...
sixwheeledbeast Posted November 10, 2024 Share Posted November 10, 2024 BTW "Type 2 or above" should really be clarified as Type 2 or better, i.e. PVC Type 2 or LSZH Type 1. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46978-play-with-some-real-kit-on-my-kitchen-table/page/2/#findComment-526362 Share on other sites More sharing options...
james.wilson Posted November 11, 2024 Share Posted November 11, 2024 I'd say no rad can heat up quick enough I wouldn't worry about it say it. Above yes is an issue. The only force that can defeat the 1.6-2.4 degree a second change is our Sun. Apart from open fires and log burners. Tldr don't worry about radiators securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46978-play-with-some-real-kit-on-my-kitchen-table/page/2/#findComment-526363 Share on other sites More sharing options...
PeterJames Posted November 11, 2024 Share Posted November 11, 2024 Dont worry about close mains, so long as you're not running in the same containment crossing paths is fine. So no real need for screened but if you use it only ground it one end. Rads cookers stuff like that wont heat up quick enough. Quad element with white light lenses is unlikely to trigger a fa from headlights from windows. Open fires log burners will cause false alarms. Some furniture such as glass coffee tables will heat up quick enough on hot sunny days and can cause false alarms. It depends on which way the room faces etc. Animals will cause fa's unless you use pet friendly detectors, But Im just repeating what everyone else is saying. To be fair though false alarms are rare nowadays though the detector technology is so much better than it was 10 or even 5 years ago. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46978-play-with-some-real-kit-on-my-kitchen-table/page/2/#findComment-526369 Share on other sites More sharing options...
a_dad Posted March 30 Author Share Posted March 30 Thanks everyone. Cable is run now. Looking to get bell, panel and box. 8 Wired Q20s, so not wedded to any manufacturer yet. Can I use my 8 core to the keypad? Can I use the 8 core to the bell box, or does it need a second power supply cable? Thanks again. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46978-play-with-some-real-kit-on-my-kitchen-table/page/2/#findComment-528711 Share on other sites More sharing options...
sixwheeledbeast Posted March 30 Share Posted March 30 On 25/10/2024 at 14:05, sixwheeledbeast said: I would wire a single 8 core to everything, Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46978-play-with-some-real-kit-on-my-kitchen-table/page/2/#findComment-528712 Share on other sites More sharing options...
al-yeti Posted March 31 Share Posted March 31 15 hours ago, sixwheeledbeast said: And not cut the spares off ...... 1 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46978-play-with-some-real-kit-on-my-kitchen-table/page/2/#findComment-528726 Share on other sites More sharing options...
