Change of broadband provider
Hi.  Have changed BB provider and now can't set alarm remotely as is permanently says not polling cloud.  How do I change BB on the alarm system please?
You may be able to change the setting on the alarm by pressing buttons,
Which button you press depend on which alarm it is....
System may have had settings programmed in the router.
I'd imagine you have an installer, you'll need to contact them.
Does enforcer allow user to search for new WiFi?
no, you need to connect to the panel as a hotspot or manually enter details....
however certain charters say ~.# or _ain't available for the alarm keypad
Hassle,,,, I glad they changed that on the hkc , allows manager to update WiFi settings saves a trip if no dual path
You could just set the SSID and password the same as your old router, or call your installer
Yeah but some of these routers now lock this to , they would need to buy third-party router
Yes it does or enter it manually
