December 10, 20232 yr comment_520912 Hello! Moved in to house, with this alarm that appears faulty, the fuse for the alarm is down, when it's flicked up the alarm sounds. We were not provided with the code! Is there any way to reset it completely without the code? Any clue why it's would be sounding the alarm as soon as it's powered on, or is that a very silly question! The TA light is on too Many thanks Edited December 10, 20232 yr by lisa1302 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46204-accents-mini-g3/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 10, 20232 yr comment_520913 We do not provide defaulting or manuals here as per our guidelines. It's possible it's decommissioned for a reason, they aren't designed to be just switched off and on from the fuse and just work. Best to have an installer recommission it, but expect them to recommend an upgrade. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46204-accents-mini-g3/#findComment-520913 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 10, 20232 yr comment_520914 1 hour ago, lisa1302 said: Hello! Moved in to house, with this alarm that appears faulty, the fuse for the alarm is down, when it's flicked up the alarm sounds. We were not provided with the code! Is there any way to reset it completely without the code? Any clue why it's would be sounding the alarm as soon as it's powered on, or is that a very silly question! The TA light is on too Many thanks Realistically scrap Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46204-accents-mini-g3/#findComment-520914 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 10, 20232 yr comment_520915 1 hour ago, lisa1302 said: Is there any way to reset it completely without the code? This isnt a yale / diy system if this was possible your alarm would be easily defeated on a break in. An alarm is a great thing and way better than doorbell cams or cctv for general crime. Im assuming you would like to have one. Get it serviced and operational is my advice. No code can just 'fix' things it appears to have a tamper fault. 24 minutes ago, al-yeti said: Realistically scrap id disagree i quite like the old ade stuff only major issue was a weak charger circuit. Looked after they last forever securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46204-accents-mini-g3/#findComment-520915 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
December 11, 20232 yr comment_520916 13 hours ago, al-yeti said: Realistically scrap Still better than a verisure system though Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46204-accents-mini-g3/#findComment-520916 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
