Honeywell FX100+ Post-Install Question
Grego
Recently completed install of a Honeywell FX100+ system. Everything has gone reasonable well, thanks in a large part to feedback from the experts on this forum.
When arriving home and un-setting the system, my wife follows the usual enter PIN and press ENT. Upon pressing ENT my wife sees the message below on the keypad.
Is there a way to stop this message from appearing? Want to make my wife's experience really straight forward.
Link to comment
Share on other sites
13 hours ago, Grego said:
The system does set and unset, it just gives that message when unset. Occasionally we also see a message BOOT-UP, but the OMIT ZONES happens each time the system is unset.
Make video
Link to comment
On 03/10/2023 at 20:07, james.wilson said:
its going into the user menu. It shoudnt do that unless the code is being entered twice.
You also shouldnt be seeing 'boot-up' as that is saying it has restarted
I ended up changing the level (42.1.User code.2) for the user from 3 to 2 and the issue has gone away.
Link to comment
21 hours ago, james.wilson said:
There is something g else there as a level 2 user doesn't have menu access. How are you or were you u setting it
Below from the manual... level 2 does exactly what is required - set and unset. Anything else I use a manager code.
Link to comment
