Grego Posted August 22, 2023 Author Share Posted August 22, 2023 On 21/08/2023 at 21:43, MrHappy said: put resistors in your old tat & get the system working before you buy some new tat ? anything with a n/c alarm + n/c tamper will work with your galaxy I have no idea what pir's are sold in the Australia market, however the panel can define its own resistor values Yes, agreed. Will keep the old PIR's and will add resistors as per @sixwheeledbeast suggestion. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46103-greetings-from-australia/page/3/#findComment-519828 Share on other sites More sharing options...
al-yeti Posted August 23, 2023 Share Posted August 23, 2023 6 hours ago, Grego said: Regarding the siren and strobe... It's hard to explain, however the RIO is going to be placed in a studio that is separate from our main house. The studio is where my wife manufactures glass jewellery, so we thought extending the new security system by using a RIO made sense. Being a separate building I figured having an independent siren and strobe made sense. I've run an 8 core cable between the house and studio, and yes agree the siren and strobe should be powered independently. I was advised outside this forum it's best to have a battery backed supply, as if mains fails, the RIO will power off causing tamper. But I figure if the RIO get's power from the panel and the siren/strobe are independently powered it might not be an issue. Yes that will work Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46103-greetings-from-australia/page/3/#findComment-519829 Share on other sites More sharing options...
Grego Posted August 25, 2023 Author Share Posted August 25, 2023 On 23/08/2023 at 16:06, al-yeti said: Yes that will work Only thing I am a bit confused about is how I wire the siren and strobe to be independently powered from an external 12 volt source? See the photo below, if I provide an external 12 volts for the strobe and the siren where does the power go in to the RIO? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46103-greetings-from-australia/page/3/#findComment-519864 Share on other sites More sharing options...
norman Posted August 25, 2023 Share Posted August 25, 2023 From the RIO to energise a 12v relay. Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46103-greetings-from-australia/page/3/#findComment-519865 Share on other sites More sharing options...
james.wilson Posted August 25, 2023 Share Posted August 25, 2023 arr you powering the bell seperate to the rio? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46103-greetings-from-australia/page/3/#findComment-519869 Share on other sites More sharing options...
al-yeti Posted August 25, 2023 Share Posted August 25, 2023 7 hours ago, Grego said: Only thing I am a bit confused about is how I wire the siren and strobe to be independently powered from an external 12 volt source? See the photo below, if I provide an external 12 volts for the strobe and the siren where does the power go in to the RIO? What particular bell and strobe are using ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46103-greetings-from-australia/page/3/#findComment-519870 Share on other sites More sharing options...
Grego Posted August 25, 2023 Author Share Posted August 25, 2023 10 hours ago, norman said: From the RIO to energise a 12v relay. Yes, I figured that was the most likely option. Thanks. 4 hours ago, james.wilson said: arr you powering the bell seperate to the rio? Yes, to ensure the RIO or panel is not overloaded, due to the panel being some distance from the RIO. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46103-greetings-from-australia/page/3/#findComment-519871 Share on other sites More sharing options...
james.wilson Posted August 26, 2023 Share Posted August 26, 2023 you will need a relay as norm or common the negs 1 securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46103-greetings-from-australia/page/3/#findComment-519873 Share on other sites More sharing options...
Grego Posted September 7, 2023 Author Share Posted September 7, 2023 On 26/08/2023 at 21:41, james.wilson said: you will need a relay as norm or common the negs Would you have any suggestions for relays? Loads to choose from, so interested to see what might be the most suitable from a professional perspective. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46103-greetings-from-australia/page/3/#findComment-520072 Share on other sites More sharing options...
sixwheeledbeast Posted September 7, 2023 Share Posted September 7, 2023 Transistorised. Handy Little Relay, Bentley or Interface Solutions are some brands we get here. Not sure were you would shoehorn these in mind you, as for our standards it should be within the tampered enclosure. I'd just take wire from straight from the controls for this reason. 1 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/46103-greetings-from-australia/page/3/#findComment-520074 Share on other sites More sharing options...
