Greetings from Australia
Normally your final exit doors would be 'final' you entry route zones would be exit. The use intruder for the rest not on the entry /exit route
  • Replies 85
  • Views 14.8k
  • Do you like cigars & chunky jewellery ?
  • james.wilson
    james.wilson
    you will need a relay as norm or common the negs
  • sixwheeledbeast
    sixwheeledbeast
    Transistorised. Handy Little Relay, Bentley or Interface Solutions are some brands we get here. Not sure were you would shoehorn these in mind you, as for our standards it should be within t
Starting to wire up the window zones (as previously discussed). My existing system (see photo below) had resistors across the common pin and zone pin (circled in blue), and a resistor in series with the windows (circled in red). That is because my current system is zone doubling.
I assume on the new galaxy FX100+ (because I am not planning on zone doubling) I just follow the diagram as previously discussed here in my Previous Post and will only need a single 1k resistor as per the one circled in red above?
Hate to keep asking, so please excuse my questions. Once I have my head around this for one zone I will be fine.
Thank you James, much appreciated.
Nice wiring....
Speaker wire?
1 minute ago, al-yeti said:
Speaker wire?
dunno, TBH I couldn't give a Castlemaine 4x ?
31 minutes ago, al-yeti said:
Speaker wire?
It's a photo of the old system. Which explains why it's being upgraded. But yes, I can see your point.
Well, if you ever find yourself in a bar brawl with a kangaroo, at least you'll have a cold Castlemaine XXXX as a peace offering! ?
I appreciate the professional installers on this forum, and I understand that my situation may seem less than ideal. I want to assure you that I am doing everything I can to improve the current circumstances. This situation is not intentional, and if there were a straightforward solution, I would have implemented it already. However, there are some challenges that will require time and effort to address. Your advice and guidance are valuable to me, and I truly appreciate your support.
Thanks, Mark
