Greetings from Australia
Another question, this time related to keypads. I have 2 x Mk7 keypads with prox. I noticed a photo on this site that had a resistor on the keypad wiring (see below).
KeypadWiring.png.fe1a2aa556d1b7f0997eaa740fc85db3.png\
So my question... If I connect 2 key/proxpads to my FX100+ I do so in series... in that I connect a cable between the FX100+ to the first keypad, and then run a cable from the first keypad to the second keypad?
Also, I assume both key/proxpads have a resistor installed on them?
Thanks in advance for any advice.
  • Replies 85
  • Views 14.6k
  • Do you like cigars & chunky jewellery ?
  • james.wilson
    james.wilson
    you will need a relay as norm or common the negs
  • sixwheeledbeast
    sixwheeledbeast
    Transistorised. Handy Little Relay, Bentley or Interface Solutions are some brands we get here. Not sure were you would shoehorn these in mind you, as for our standards it should be within t
Yes a daisy chain the resistors at each end. However if the runs are short they won't be needed
I cannot quite make out the colours... is it a 680 kΩ resistor?
  • 2 weeks later...
I have several zones that are made up of windows that have reed switches and they go back to my current panel. The reed switches dont have individual resistors, and retro fitting is not an option. I assume I can install a 1k resister as per the diagram? Or do I need to do something else?
All guidance appreciated.
Are they looped from window to window or some other configuration?
You will need 2 resistors if this is a galaxy on deol
You say it's not an option... but that's what I would do.
Wouldn't entertain all that stuff on one zone.
Yes, there are 'window' zones that are divided by windows on the north, south, east, and west sides of the house. Each window has a reed switch daisy chained to a 'zone' cable that runs back to the alarm panel. For example, a cable runs from the first window reed switch on the east facing side, to the next east window, and then the next... etc. From the last east facing window the cable runs back to the current alarm panel. The current alarm panel has a resistor on the panel connector (see photo up the top of this thread).
Doors are on separate individual zones. Retrofitting a resistor for each window reed switch would be challenging, as the cabling was installed when the house was constructed.
Hope this helps.
Yes, understood, and can see why it might be best option. Each window zone has at most 3 or 4 reed switches, some less. Retrofitting resistors to each reed switch would be significantly challenging as per the reasons I explained in the post above.
