Upgrade from DS2 to AHD/TVI/CVI
Ebay will give you a higher chance of finding junk but ok...
KVM style is the type, others are just passive which will be no better than an extension cable.
Used ones with HDMI passthrough for a local and remote monitor plus USB / IR both ways over single Cat6.
Link to comment
Share on other sites
8 hours ago, sixwheeledbeast said:
They come in pairs require local power and send both over UTP. Distance varies based on Category of the cable Cat5e/Cat6 etc.
Search "HDMI/USB over Cat5"
If you don't go the full system route you will end up buying convertors or other tat to get all the functionality you want to retain to work if it's compatible at all.
It's highly possible the PTZ aspect or some of this functionality you have is not really required.
Hard to say without seeing the site, you make the site sound like an average detached domestic property with neighbours, while what you explain of the system feels like it was designed back in the 90's, for a scrapyard with night guards...
Convertors only for the cvi stuff right? Most other or some recorders can do ip tvi an ahd ?
Link to comment
yeah I thought the KVM type looked more likely to be what's required.
Obviously I know ebay isn't ideal for everything, but my budget is ridiculously small so I'm kinda forced to go along that route. My health deteriorated so I've not got a proper income.
Link to comment
On 29/05/2023 at 18:34, MrHappy said:
you buying used items from ebay ?
I don't believe this keyboard-
DS-1004KI PTZ Keyboard Hikvision
works with those machines, I think this keyboard is circa 8 year old
There is also a DS-1006KI controller that I've spotted (new), and I'm wondering if that would work a DS-7308HUHI-K4 DVR system, as that system does have seperate terminal inputs marked for a keyboard controller. Ideally I'd like the main monitor to have joystick/keyboard control over the cameras and DVR, even if then a KVM extender is installed for the lesser-used monitors 2 and 3
Link to comment
You mean it has rs485 or 232 or something like that? Or specifically says keyboard input in back of machine
The protocols can be selected on keyboards and the hikvision ones all usually work
Link to comment
