June 27, 20224 yr comment_515102 On 06/05/2017 at 06:57, KB RED said: Hi I have an Optima/Accenta and in the last few days the alarm has just started going off for now reason (at midnight but at 3am yesterday). i have 8 zones and the panel reads like this after it has been reset 12345678 TP F0000000 00 Would really appreciate some help and advice. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45160-accenta-fault/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 27, 20224 yr Author comment_515103 I got fault on G4 Accenta 12345678 TP does any one knows how to get rid of it please, the alarm goes off without the reason hope someone knows the answer for this thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45160-accenta-fault/#findComment-515103 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 27, 20224 yr comment_515104 Can you expand on the fault a bit more? Does it activate while unset? What is shown when it goes off? When was it last serviced? How often and for how long has this been happening? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45160-accenta-fault/#findComment-515104 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 27, 20224 yr comment_515105 2 hours ago, Arun said: I got fault on G4 Accenta 12345678 TP does any one knows how to get rid of it please, the alarm goes off without the reason hope someone knows the answer for this thanks Tamper circuit open? Loop it at panel to see if it clears the fault , if it does it means you have a tamper fault on sensors or cable perhaps, , Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45160-accenta-fault/#findComment-515105 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 27, 20224 yr comment_515106 123456789T probally means it don't change to battery when the mains fails / dips.... Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45160-accenta-fault/#findComment-515106 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
