20 minutes ago, james.wilson said:
If your getting 12v on your meter between bell trig and 0v the panel isn't driving the bell.
Touching the bell trig to 0v in the panel proves this.
Yeah that’s right. The old bell box must have been driven differently?
Solved it. When I started this post, I was looking at a way of disabling the current bell so I could remove the lid without it going off.
I must’ve forgotten I’d been into the Engineer > Outputs > 1003 and switched it to not used instead of Bell. Switched it back and tested ok.
should have done it all on one day. Stupid me.
thanks for all your suggestions anyway guys. Have a good weekend.
2 hours ago, al-yeti said:
So then if panel isn't faulty you may have changed the polarity by mistake
Make sure it's neg and do a panel restart before testing it again
And of course as above did you change bell delay ....
So much the same changing polarity changing output type and so on all in programming
Well done for remembering
47 minutes ago, sixwheeledbeast said:
15 minutes of tea drinking and paperwork?
8:30 to 11:00 to change a 9651 to a p48 inc moving spur, with ewd + decoy
1hr for panel 30 mins each for ewd, decoy & rkp
 There's probably a further day to add other expanders & circuits & cat 5 for comms
1hr travel each way?
Setup
Analyze
Get pallets of doom in order
4hour? £150?
Register a new account
Sign in
