Eurosec CP8L "KP Tamper" Error
1 hour ago, AlexL said:
Will be my last resort as costly.
a new endstation & keypad will cost less than a cheap android phone from argos ?
  • Replies 21
  • Views 36.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • gently twat the keypad with the handle of screwdriver... this will simulate the day 2 day movement of the house,    eg - kids slamming doors, a fat wife waddling up the hallway, a dpd van bo
  • for a super-duper alarm man like me 2hrs   1/2 hr to replace the rkp 1 hr to swap the controls 1/2 to fake some paper work & demo to the end user ?
  • sixwheeledbeast
    sixwheeledbeast
    Option 3 is junk and not an "alarm system". You need to decide if your doing it yourself or just getting a man that know what they are doing to just do it in half a day. We can't make that d
Posted Images
Quite right MrH, but endstation installation is probably not a simple swap, and I am also not sure whether existing sensors/wiring will be compatible either ...
  • 3 weeks later...
Hi Guys, thought I'd update on the status.
Ordered KP, while waiting for it to arrive the screen (power) on KP gone completely so it wasn't responsive, basically dead. When new arrived, upon swapping - nothing changed on the new one, i.e. as if there wasn't power going into it (so I think it might be something on control panel all along). I did however managed to trigger the control panel and alarm. With effectively no KP to turn it off, had to pull the battery and fuse out and few wires in the bell to shut it down :(. So, regrettably, will have to go with full replacement as was suggested before :).
I am sure this has been asked many times (so don't shoot), but any advise on general approach:
1. Buy something (wired) on my own and ask installer to install it.
2. Go with what installer recommend (I think they use Pyronix)
3. Just go with wireless DIY, e.g. ring etc ? ?
Thanks for advice.
We can't make that decision but you seem to want the system working and you have already worked out the hard way spending money to fix nothing, installer seems sensible?
Thanks for advice.
Have you tried wiring it directly into the panel on a short bit of wire? Also check the fuses,fuses are there to save the panel when amatures decide to play around.
1. I wouldn't install something purchased by a customer, it opens up all sorts of warranty issues.
2.This would be my recommendation
3. All of this stuff is one way wireless, as swb says not an alarm system. The Ring alarm will need to be more reliable than the doorbell to be any good.  It really comes down to what type of burglar you are likely to attract.
ring and simplisafe etc have burglar guides on youtube, look yourself for howto guides on defeating
cool, what do they have in the way of disabling a tracker on 2022 Cayman ?
