Galaxy 48 Rio, zones not working
Hi all, following a few garage break-ins on our estate lately, I decided to change to a Rio from a single zone so I can add a PIR.
Everything went ok, the system detects the Rio, Rio set to slave via link 4, but I can only get one zone to work.All are set to intruder.
zone 8 Roller shutter contact - works normally
zone 7, PIR -  Nothing
zone 6, Door contact, Nothing
I did have the Door Contact working on zone 2 at one time when I tested it before installing. It is set to address 3
I have searched online for guides on installing nd programming, but can find very little. Photo is from when I tested it.
Thanks for reading, Keith
Edited by Keef
Why are you using it as a slave. That's for shunting etc
Lol I wondered why he was doing that
By the sound of it I am doing it in error. I followed another post I found online. I have only cut one side so I can easily reattach it it.
Hopefully you lot can tell me the correct way to do it.
There are only 1k resistors in the unused zone terminals, plus 2x1k on the other 3 zones
Thanks, Keith
Edited by Keef
The 1k restistors should be in the devices not at the rio
Sorry, not worded very clearly.
The resistors are at the 2 contacts and the PIR, only the unused zones have them at the Rio
Before anything remake link 4
www.nova-security.co.uk
www.nsiapproved.co.uk
Link 4 remade and still the same ?
Whats the panel you are using, RIO is addressed as 3 so the circuits would start at 1031
The wiring looks like its going to ciruit 1 and 2 on the rio but the leg of circuit 1 looks like there isnt anything in it on the picture.
In your first post you mention zones 6.7.8 but the EOL resistors are in 6,7,8 and where are you getting the power for the PIR from?
