Strange beeping !!!
55 minutes ago, sixwheeledbeast said:
We are still talking about a Scantronic 9800 here tho, aren't we...?
probably a kidde carbon monoxide detector ?
  • Replies 37
  • Views 8k
  • PeterJames
    PeterJames
    Check your drawers for an old smoke detector
  • MrHappy
    MrHappy
    If I was a betting man-   I'd wager you've more chance of getting a hand job off her majesty the queen than your powered down alarm making the "chirp"   You've probably got a brand
  • james.wilson
    james.wilson
    I'd suggest you power it all down then find out it's a battery operated bit of junk, nest smoke, other smoke detector then I'd look for alarm clocks birthday cards etc. A powered down alarm is just th
not anymore its something else. No 9800 keeps sounding with no power. But its 25 ish yr old so its more likely to be the old alarm vs the past it 10 yr old smoke/co2 etc detector
Don't forget the Mitcheldean witch trials-
Any strange bleep from a powered down alarm, needs the services of an exorcist..
I used to be medium, but as I got fatter my shirts are now all large.
On 18/06/2021 at 19:47, MrHappy said:
anyone got the no. for derek acorah ?
I know he;s dead but that should not be a problem....
Derek pakora, he was a rice guy
Edited by aissecur
  • 4 months later...
from what a remember, scanny 9800 doesn't have an onboard buzzer..... i get this all the time... best thing is to shut all doors in house, walk around to see where noise loudest...due to frequency of beeps, it can throw its location around a bit... could be something in cupboard with scanny panel...but if you downpower the panel and leave it a while, and you still get chirrping, it definately is not the panel..
Down power the panel you'll get the bell ringing outside, that'll help find an intermittent beep...
