Texecom Odyssey 1 Bell Box
Hi All,
I’ve finally gotten around to wiring out Honeywell Galaxy 20 alarm system. The Bell Boxes have been on the wall for about 3 yrs and were installed by our electrician. I decided it’ll be worth testing the bell boxes to confirm they are working as expected. The rear box is working, connected to 12v psu I get slow alternate flashing LEDs. I can then operate the strobe and sounder by grounding the appropriate wire. The front bell box however is not working. When connected to 12volts the sounder goes off for ~5secs and the left hand led flashes. Looking at the instructions this indicates a tamper fault. However if I measure the resistance between the tamper wire and 0v wire I get ~2.5ohm, which is almost identical to the rear box. Do you think this is actually a fault or could it be because the onboard battery needs charging? Unfortunately I do have a set of ladders to reach the bell box.
Any advise great fully received
Nick
On a bell the tamper isn't a switch it should be 0v if the tamper is ok
Meter between tr and ho + you should get >12v
If using two boxes you would usually series the bell tampers.
For Texecom bells the first one is wired "normal" and then the second bell is seriesed with the microswitch terminals leaving the tamper terminal unused (as per instructions).
I would suspect there is a tamper issue if the bell is stuck held-off.
I have measured the voltage and I do get 12v between these terminals.
I am planning to borrow a set of ladders to check the tamper circuit and wiring at the weekend. Reading the instructions it would appear the internal battery needs to be enabled. Could this be the issue? The tamper line is providing 0v, confirmed by 12v reading between it and +12v. Could a defective internal battery be the problem?
I also now realise the boxes should have their tamper circuits serialised. The rear box however is even less accessible than the front box (due to roof pitches on ground floor extensions making ladder access impossible). I was therefore planning to use the tamper line of the front bell to feed the 0v line of the rear bell. The tamper line of the rear bell would then go back to the alarm panel. I am also concerned the current load of both boxes may be too much for the panel. In which case I was planning to only connect the strobe on the rear box.
34 minutes ago, PeterJames said:
is there a 5 sec battery link on these boxes?
No  texecom are preset to 15 min and can't be adjusted
Seems like the front bell box has failed    i had a couple odysseys fail in this way from water ingress
Edited by Imnotshankled
Texecom odyssey boxes dont monitor the battery
Depends if it's Grade 3 model, even so it's a separate output.
Thank you for the advice, you’ve confirmed my suspicions. I’ll get it off the wall this weekend and test it on the bench. But sounds like I need a new box
