Galaxy Flex 50
34 minutes ago, mikejc said:
Will do. Bought it used and only get a few days to determine if faulty so hopefully no errors. Didn't pay much for it so was a risk worth taking
How much for control panel and keypad , show me receipt lol
3 hours ago, mikejc said:
Right I misunderstood you. Are the pet ones not reliable?
Your asking a 20 ish quid at the low end to determine that the movement wasn't a person. As 6 I hate them haven't found one I'd use yet
I rate the Bosch ones but still I would only retro them, best to design the system for pets with perimeter kit from the start.
Use programming to adapt the system and omit sensors not use sensors that are designed to detect less.
All good so far. Enabled engineers mode and was able to power down using the keypad. Hopefully this means the keypad and board are ok.
Thanks for all your help
Ok thanks. I'll keep this in mind when looking into PIRs
