How do I get this to work?
Hello everyone.
I'm wondering if there is anyone that could point me in the right direction on how to wire my alarm system up.
I'll tell you what I have and what i want to re-install. (it will be a few things less than the original setup)
Long story short, i use to own a plumber shop and recently closed it down. However, i did manage to pay of the alarmsystem and took it with me.
I now wish to install this at home (250sqm house) but in the heat of moving out from the shop premises I never marked the cables up befor cutting them.
The things I have today (and had installed in the shop is:
1 x Main unit Honeywell FX100 C007-L-SD V3.19 (with the A081-00-SD GSM board and LAN module on the left hand side)
1 x Keypad CP051-30-01
1 x Rio C078
2 x Sirens B-503-0010 (marked 1021 & 1022)
2 x Smoke detectors Aritech DP721RT (marked 1017 & 1018)
5 x PIR Interlogix DDV1016AM (marked 1003, 1004, 1011, 1015 & 1016)
3 x Doorsensors/ magnets Alarmtech B-582-0013 (marked 1001, 1002 & 1004)
1 x Camera Axis M1145-L
1 x Axis companion switch 4CH, 5801-351-01
I could really need some help on wiring all these components in to the Rio and the main unit.
Should i have a CAT5 cable pulled all the way from the router down to the main unit to the LAN module for the camera or from the camera straight to the router, or one cable from the router to the switch and from the switch to the main unit?
What should go through the Rio and what should go straight to the main unit? And most important what cable goes where?
I have all the cables and will pull it all this weekend but it would be great to get some help with the wiring to get it started.
How do I change the phone number i the alarm system, that the alarm calls in an event?
Is there an app I can use to check the camera and admin the alarm remotely?
Would really appreciate any help towards getting my old/new alarm system up and running.
kind regards,
Henrik from Sweden.
  • Replies 63
  • Views 15.5k
  • Put your hand in your pocket and purchase a Pyronix Enforcer wireless  kit. Save you lots of hassle and well worth the ££.
  • Not sure id agree on the enforcer bit but its the right idea if you have no clues on what to do, wireless is ideal for DIY
  • sounds very unlikely ?
Please dont post the default codes in public.
You would be better breaking your questions down, there are far too many questions in one topic, it makes it too messy trying to answer everything you have asked in one post
But the galaxy is far superior
21 hours ago, Henrik said:
Hello everyone.
1 x Rio C078
kind regards,
Henrik from Sweden.
Leave coms til last , mount your panel and keypad , c078 , and the coms boards should already be mounted hopefully
Switch on and see what faults you get, work through one by one
Then go for the door sensors marked 1001-1004 which will be the first four zones on the board (1003 not being used it looks)
Unfortunately I’m not aloud to have a wireless alarm system due to having a goldsmith studio in the basement. My insurance company demand a wired alarm system.
Insurance? So they don't mind you DIY installing not know what your doing ?
No, apparently not!
