Change bell box
14 hours ago, PeterJames said:
pasted to make it easier
You should leave this for engineers to sort out ......
I did, I cant be rarsed with wires in holes anymore. I just thought if the pictures were there someone might actually help. Mind you I cant see the panel connections that well the picture is to poor
TADB is easy....
What's hard is trying to think why he wants to keep an optima +2
Well it's currently got +ve going into the bell -ve and the tamper linked out so it's a bit of a mess and no guarantees it's going to work properly.
It also looks like a 25+ year old  optima that would have been worth upgrading at the same time....
T tamp, A -ve, D +ve, B trig.
The wires in the control panel are wired for the old bell box which still works but the cover is broken. That’s the only reason I want to change it.
It must be lucky/well looked after... Been a good while since I've seen one without black burning around the regulator, have the correct aux voltages and capable of charging the battery at a decent rate.
