Galaxy 3-48 'line test call'
Hi
had this alarm set up for a while, (it was installed when we moved in )  but have noticed that on the phone bill is a call every night to an 0844 number, which is apparently an alarm test call?
sounds logical, but is there any way of disabling it please?
6 minutes ago, dave36 said:
Hi
Delete the number and it won't call
Is it under contract? Monitoring?
I would assume the system is monitored, if so you should contact your installer to see what they can do.
 the alarm was on a contract with previous owner of building, but we haven't got it on a contract..  i have tried changing and deleting number in communications/telecoms section , but i cant find any reference to this 0844 number. however its obviously in there somewhere though. It looks like it only makes the call once a day if thats any help.
any advice/help gratefully received
As above its probably a test call under tel no 1.  Its a requirement for grade 2 communicators to test the alarm path at least once every 24 hours to prove it could use it if needed
Number has to be in there ? What menu option you look in?
I've been right through the 56 communications section which i assumed where it would be
56 - 1 int telecom 07 autotest
www.nova-security.co.uk
www.nsiapproved.co.uk
that is set to 00:00
