Honewell Galaxy Flex 050 v.3.37 factory reset or code
  • Replies 22
  • Views 14.4k
10 minutes ago, mariorainy said:
Understand , do you know who can help? thanks
Its either the Equaliser or the A-Team ?
TBH I've had a drink & are getting a bit mixed up...
Will Galaxy Dimension programming cable help ? Will I be able to upload newer firmware and then get default codes from the system ? thanks
Local engineer probably can default it for you
On 24/08/2020 at 22:30, mariorainy said:
local engineers dont use this brand...no help from them
Pretty much everyone knows galaxy, if they dont know it its like saying they have never heard of ford as a mechanic. Not knowing it well is different. IMO people should specialise do what they do and do it well, not ive seen one of these before how hard can it be. Got the same issue with my Bosch Boiler at home, needed a specialist and after a while found one.
