I have a BT Home Monitor VP1000 which started to beep a few days ago (3 per minute) but with no fault registered. I checked the manual and tried to switch off for 4 hours but did ot work. It also ays in the manual that it will not beep at night but it does. I have now switch off at the mains and also disconnected the battery and it is still beeping. It is driving me and the family nuts! Any ideas to resolve the problem?
  • datadiffusion changed the title to BT Home Monitor VP1000 problem
8 hours ago, sixwheeledbeast said:
A non- related battery powered smoke alarm?
8 hours ago, datadiffusion said:
Suspect it is your smoke alarm
id go with the above, the intruder alarm is always first suspect but often isnt
im sure many maintainers have calls for the same when its battery powered stand alone devices, smoke alarms, alarm clocks in draws, heating systems. I even had a call to 'music coming from all rooms with a pir' turned out it was her birthday and she was walking round with a singing birthday card
  • Upvote 1
You are all right it was the smoke alarm - situated close to the intruder alarm control box so difficult to differentiate betwenn the 2 especially with my hearing. Thanks all
you not the first and wont be the last dont worry glad your sorted
6 hours ago, datadiffusion said:
Thanks for fessing up ?
qfa few do
Register a new account
Sign in
