Sideshow Posted May 26, 2020 Share Posted May 26, 2020 Hi, After some help. I have 10 year old Eurosec alarm system, and when i went to change the internal battery i noticed a loose Blue wire, which i believe is the Trigger wire from the external alarm?. Any idea were this should connect to? I have also noticed that the external alarm has stopped working. Quote Link to comment Share on other sites More sharing options...
james.wilson Posted May 26, 2020 Share Posted May 26, 2020 the bell trigger connection Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
PeterJames Posted May 26, 2020 Share Posted May 26, 2020 There are probably many wires that are not used inside a control panel do a bell test if it works then its not a bell wire. Then set it if it sets then its likely not a wire in use Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted May 26, 2020 Share Posted May 26, 2020 I agree with PJ, was it stripped back as if it should be terminated somewhere? Quote Link to comment Share on other sites More sharing options...
Sideshow Posted May 27, 2020 Author Share Posted May 27, 2020 Bell test works and system sets okay Quote Link to comment Share on other sites More sharing options...
PeterJames Posted May 27, 2020 Share Posted May 27, 2020 29 minutes ago, Sideshow said: Bell test works and system sets okay I would guess that wire was unused then Quote Link to comment Share on other sites More sharing options...
aissecur Posted May 28, 2020 Share Posted May 28, 2020 On 26/05/2020 at 21:02, Sideshow said: Hi, After some help. I have 10 year old Eurosec alarm system, and when i went to change the internal battery i noticed a loose Blue wire, which i believe is the Trigger wire from the external alarm?. Any idea were this should connect to? I have also noticed that the external alarm has stopped working. If you want to keep your system operational I do hope you change your battery more often than once every 10years Quote Link to comment Share on other sites More sharing options...
Sideshow Posted May 28, 2020 Author Share Posted May 28, 2020 2nd battery in 10 years Quote Link to comment Share on other sites More sharing options...
al-yeti Posted May 28, 2020 Share Posted May 28, 2020 1 hour ago, Sideshow said: 2nd battery in 10 years So expect problems Quote Link to comment Share on other sites More sharing options...
Guest Posted May 28, 2020 Share Posted May 28, 2020 1 hour ago, al-yeti said: So expect problems Nah he just has nieghbors who he really wants to annoy Quote Link to comment Share on other sites More sharing options...
