Eurosec Alarm System - siren / wiring issues
  • Replies 23
  • Views 8.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • james.wilson
    james.wilson
    Id say every 5 years is fine. Better to replace before panels report it to prevent damage but modern panels seem to do better with failed battery's than the old dumb stuff
Just now, Sideshow said:
Definitely checked and heard the outside bell
Ok so how did you activate it. IIRC on the eurosec the bell can be delayed on certain activations, ie timeout.
Set the system and trip a NON exit entry zone. This should sound the bell.
if working on bell test then can only be there is a bell delay set or tripping an entry timed zone and not waiting until full entry time has expired.
You need to check the zine you trigger is programmed  as a 12hr (ie instant alarm on zone)
failing that press & hold 1 & 3 on the remote keypad to activate the panic, this will give you a full alarm condition
