scantronic 9600 exit timer problem
They are renamed as Eaton Im no expert on their panels, but I think the Ion is their offering
  • Replies 25
  • Views 4.4k
  • sixwheeledbeast
    sixwheeledbeast
    Map7 on the zones would do the trick, now where did I park my DeLorean....   Sounds like a nice job to swap out with new controls and a smart PSU, split that detection the best way possible.
  • **edit**   take your pic any commercial control would do   the issue you'll have the amount of current drawn,   if your doing DIY & have not moved an over expanded se
  • sixwheeledbeast
    sixwheeledbeast
    All part of other companies, it's survival of the fittest in this game. Aritech = UTC Castle = Hik Menvier = Eaton
Ah no surprise i couldn't find anything then haha
What are aritech, castle care tech and menvier doing these days? been a while since i have messed with alarms
Aritech = UTC
Castle = Hik
Menvier = Eaton
If you like the way the scanny works, although to be absolutely fair you could put anything in, the iOn is your best bet, though you would need to work out
exactly how many circuits you need if they are doubled up. No real advantage in anything other than the iOn 40H, that way you get wireless should you ever
want it (fobs, also if you ever replace windows I find wireless vibration contacts easier to place neatly). The 40H has 10 circuits on board and you can
get expanders in 10's - if you are REALLY lazy the expanders allow double pole wiring if you can't be arsed to convert to EOL (though I would recommend you do).
I know you don't want a smart alarm, but the iOn comes with 100% free app based self-monitoring, which you can also completely disable :)
but the ion has awful 1 way wireless?
It does for sensors I imagine the OP like me won't be using it for sensors though, except the odd bit of perimeter protection (fobs and keypads are 2 way)
Edited by datadiffusion
