i-on40H SD Card
Trying to install a micro SD card in a newly installed i-on40H and I get an "SD Card Error 2".  Are there any specific formatting/size/structure requirements for an SD card to work
What size card and what did you format it with
I don't know the i-on but I would imagine most devices like that will be FAT
Whats it use an sd card for?
Camera recordings and upgrades (SD upgrade path is useful if you come across a really early one and want to jump firmwares without going around the houses)
FAT32 AFAIK
Funny enough I am just about to set up a bench test of an Ion-30R with an Eaton IP camera.
FAT32 AFAIK
Isn't there a limit on card size aswell ?
Yes, it might be quite small.
I would expect a 32GB card to work no problems. That is conveniently the max size Windows formats to FAT32 and the cut off for SDHC and SDXC.
Beyond that if larger SDXC cards work I'd expect it to be fine upto 2Tb unless they have designed some weird size/file restriction into it.
Yes that rings a bell. Pretty small by current standards I guess though so maybe OP has whacked something bigger in.
well it will either be 2gb or 32 limit imo. Dependds on the age i suppose
