Automatic garden and hanging basket watering system
  • Replies 81
  • Views 15.5k
  • Pricks ...
  • Nova-Security
    Nova-Security
    Irrigation system covered   Next, artificial lighting and electric meter by pass
  • Lol I've just been doing a pir activated motorised valve jobby, issue with the solenoids are hammer when they are activated.
Also sorting out my watering system today, nothing fancy just solenoid and a hozelock kit. Controlled via simple z-wave relay as Fibaro has watering program built in based on weather etc...
Hadn't really considered the hammer issues.
Edited by datadiffusion
The speedfit is just being used inside. Will be painted for the 200mm at each basket. Wanted to use it as its in the house and i didnt want any leaks. Ive done it without joints thats why the 4 way manifold.
Used this solonoid
https://www.amazon.co.uk/Electric-Household-Appliances-Industrial-Equipment/dp/B07WGZ62G2/ref=sr_1_12?crid=E223TKA97H7R&dchild=1&keywords=240v+solenoid+valve&qid=1586805698&refinements=p_76%3A419158031&rnid=419157031&rps=1&sprefix=240v+sol%2Caps%2C146&sr=8-12
for about 12 quid
using a sonoff mini
https://www.amazon.co.uk/Compatible-Control-Function-Support-Required/dp/B07TRSWY23/ref=redir_mobile_desktop?ie=UTF8&aaxitk=vILe6pEXAnEN4p-U9Y5c2g&hsa_cr_id=2512088930502&ref_=sb_s_sparkle
Just cos i have them i dont need the switch input but may add it to the enclosure depending on how the auto goes with the weather etc
Currently running on a hose pipe feed but will be plumbed in properly
The out hose connection is for the veg patch
The remote is for something else but i was playing with it. It will be automatic on a timer using the sonoff.
Like the manifold.
Ifttt is ideal for the sonoff with something like Weather Underground.
Or even on the schedule for sunset with inching set up.
Personally I'd see the solenoid as a potential weak/leak spot and I'd look to have it outside if at all possible.
it is outside. In wp enclosure
ive got to consider freezing though too
