used menveir / scantronic i-on
3 minutes ago, MrHappy said:
I had hiwatch camera on port 85 on the bench the other week & knew my work router to house router was working on port 85 in the past
it appears the controls do not take up the software changes until power cycled or a code in entered on the psychical keypad
however the downloading software still won't load on the intended win8 machine, the same file loads on my lenovo & acer laptops
there all 64 bit machines....
You opening a can of worms
Let's talk about hiwatch, why you got that on the bench , re badging to hikvision only ? So it becomes pro stuff
  • Replies 130
  • Views 27.6k
  • MrHappy
    MrHappy
    it appears "cooper security" have a new product range ?
  • sixwheeledbeast
    sixwheeledbeast
    You should know by now there's always a silent P in Bath.
  • PeterJames
    PeterJames
    I am guessing that this is an abandoned building, I am surprised that the power is on. Logan I am sure that you already know this but you really should not be on top of a lift messing around in an aba
1 hour ago, MrHappy said:
should you change the banner text-
download it into the controls, the old banner is displayed until the user code is entered,
odd...
So any chance in switching to ion as your main panel or dropping the enforcer for this
Scanny wireless have an all in one? Onboard keyboard jobby?
I like the square i-ion keypad & massive endsation
But won't be moving towards them.
27 minutes ago, Logan said:
Diy? I dont install this yellow peice of S***
But you are DIY ? DIY prices , DIY installs ?
Eaton scantronic I know your reading this , helicopter above forum
You missed the boat , need all devices two way , I might have switched to ion aswell
Only reason they keep app platform free is because they probably collapse by now if they didn't
Being NSI Gold goes way beyond how tidy the wiring is in the panel. that's likely down to one engineer and their untidy workmanship.
There is a whole company, employees. training, testing, maintenance and audit trail behind that job.
2 hours ago, Logan said:
Erm my installs are done better than some NSI gold companies    btw i dont use the enforcer unless i have to
I mainly still install wired systems of all the systems i installed i only used 1 enforcer panel as i wasn't able to run cables as the house was Newly decorated
Is that battery dated ?
If so why would you have to move the battery it to see the date ?
Those alarm cables marked?
Why have you got main & low voltage shoved though the same ungrommeted hole ?
Why is there no stress relief for the mains
If you wish to post an example of your specification that's when the proper fun starts...
Quote
Terminal Allocations: A Relay (see p.xx-xx)
1 C contact
2 NC contact
3 NO contact
im guessing whatever is connected to A3 doesnt work very well?
also you have a .5mm 2 core flex whats that doing?
