sixwheeledbeast Posted February 6, 2020 Share Posted February 6, 2020 I'd say new battery check the voltages, see how it goes but don't expect it to be reliable. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43513-ademco-accord-8-help-with-tamper/page/2/#findComment-494956 Share on other sites More sharing options...
Timmymeads Posted February 7, 2020 Author Share Posted February 7, 2020 Okay so I entered the code followed by a number 1. This is the code I written on the alar instructions paperwork. Nothing happened. It’s showing power and On with the green lights. I wonder if I did reset it when it’s in tamper mode? Thing is I don’t know how I can when the box is open and it’s in tamper when resetting? How do I possible get the new code? Can I somehow get someone to hold down the tamper button why I disconnect battery etc and mains then carry out the reset? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43513-ademco-accord-8-help-with-tamper/page/2/#findComment-494968 Share on other sites More sharing options...
al-yeti Posted February 7, 2020 Share Posted February 7, 2020 1 hour ago, Timmymeads said: disconnect battery etc and mains Then bin it 1 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43513-ademco-accord-8-help-with-tamper/page/2/#findComment-494971 Share on other sites More sharing options...
MrHappy Posted February 7, 2020 Share Posted February 7, 2020 7 hours ago, Logan said: Correction send to me for my collection nah, stamp on it then bin it.... Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43513-ademco-accord-8-help-with-tamper/page/2/#findComment-495000 Share on other sites More sharing options...
MrHappy Posted February 7, 2020 Share Posted February 7, 2020 6 minutes ago, Logan said: Still want a pyronix paragon aswell I've binned more than 1! Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43513-ademco-accord-8-help-with-tamper/page/2/#findComment-495003 Share on other sites More sharing options...
MrHappy Posted February 7, 2020 Share Posted February 7, 2020 2 minutes ago, Logan said: Still better than diy alarms err... the only ungraded stuff I see is removing optima's Pyronix, panel's paragon, conquer, & sterlings where proper dogshit, I aslo once binned a martix ? Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43513-ademco-accord-8-help-with-tamper/page/2/#findComment-495008 Share on other sites More sharing options...
MrHappy Posted February 7, 2020 Share Posted February 7, 2020 8 minutes ago, Logan said: I prefer the castle caretech side of pyronix I assume castle was purchased as their own controls where a bit duff, sold well but duff... Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43513-ademco-accord-8-help-with-tamper/page/2/#findComment-495010 Share on other sites More sharing options...
al-yeti Posted February 8, 2020 Share Posted February 8, 2020 9 hours ago, MrHappy said: I assume castle was purchased as their own controls where a bit duff, sold well but duff... You wish you had the wisdom instead of enforcer ......... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43513-ademco-accord-8-help-with-tamper/page/2/#findComment-495019 Share on other sites More sharing options...
Timmymeads Posted February 8, 2020 Author Share Posted February 8, 2020 Can I do a master reset by cutting electric/opening the mains box. Make the tamper pressed down with tape (as if the box is shut onnit) then mains on, disconnect x1 battery positive wire. Then mains off. Then mains on again and connect battery then run to panel and hold * & # together . Apparently that puts it in reset? It will then flash up the master number sequence ? Does that sound right? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43513-ademco-accord-8-help-with-tamper/page/2/#findComment-495020 Share on other sites More sharing options...
al-yeti Posted February 8, 2020 Share Posted February 8, 2020 40 minutes ago, Timmymeads said: Can I do a master reset by cutting electric/opening the mains box. Make the tamper pressed down with tape (as if the box is shut onnit) then mains on, disconnect x1 battery positive wire. Then mains off. Apparently that puts it in ready for the bin ? It will then rip off wall by its master ? Does that sound right? That sounds good , if above is actually what you meant 1 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43513-ademco-accord-8-help-with-tamper/page/2/#findComment-495022 Share on other sites More sharing options...
