35 minutes ago, Logan said:
No it isn't.  Its for vista, accord and galaxy 16 16+ and 90
err the book say 4140/ 4170
if you also have an accord book in the binder it might but prudent to post a pic of that,
I once had a 4140 on redcare.... not touched it 15yrs ?
Drove by on tuesday,  my sticker are still on the EWD's
Customer is well happy - he can show the world he is protected by a trading alarm company ;)
53 minutes ago, Timmymeads said:
I know the engineer code now and master code - Do I have to program my zones?
How do I enter programming mode
When you defaulted you reset everything and will be time consuming to sort out
I assume before you did the default you made sure programming manual was available etc?
1 hour ago, Timmymeads said:
Not sure... what u mean - I just wanted it to work :(
Well you need the manual , and you need to understand what defaulting does and what the alarm does
It's better to scrap it tho and if you intend to try and make "something work" get a scantronic 9651 and it will be easier to setup and you can work your way through the faults over the 6minths to few years if that's what it takes
Sometimes it may work to an extent but you can never realised the problems , you will have to get or ask for help on each problem that occurs
Register a new account
Sign in
