March 19, 20206 yr comment_497178 Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43350-honeywell-touchcenter-change-language/page/2/#findComment-497178 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 19, 20206 yr comment_497183 The language isn't the issue fortunately, anybody able to help set this touch centre up or reset it some how? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43350-honeywell-touchcenter-change-language/page/2/#findComment-497183 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 19, 20206 yr comment_497191 31 minutes ago, robbo173 said: The language isn't the issue fortunately, anybody able to help set this touch centre up or reset it some how? Do you have English version instructions? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43350-honeywell-touchcenter-change-language/page/2/#findComment-497191 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 19, 20206 yr comment_497193 Yes I have the full English instructions, the issue is that it doesn't seem to recognise the panel and won't go through the addressing or language options on power up even after pressing the reset button! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43350-honeywell-touchcenter-change-language/page/2/#findComment-497193 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 19, 20206 yr comment_497208 1 hour ago, robbo173 said: Yes I have the full English instructions, the issue is that it doesn't seem to recognise the panel and won't go through the addressing or language options on power up even after pressing the reset button! Can you upload some picture of the unit Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43350-honeywell-touchcenter-change-language/page/2/#findComment-497208 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 20, 20206 yr comment_497210 OP, you will need to place the latest English touch center firmware on a FAT32 formatted SD card, then insert the card into the CP045 and power on. The touch enter will then re-flash its firmware and default. You should have received an SD card and firmware with the new touch center. If you are a Selfmon customer, contact me via the Selfmon email for support. If not, then contact your installer. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43350-honeywell-touchcenter-change-language/page/2/#findComment-497210 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 20, 20206 yr comment_497211 20 minutes ago, GalaxyGuy said: OP, you will need to place the latest English touch center firmware on a FAT32 formatted SD card, then insert the card into the CP045 and power on. The touch enter will then re-flash its firmware and default. You should have received an SD card and firmware with the new touch center. If you are a Selfmon customer, contact me via the Selfmon email for support. If not, then contact your installer. All available online though Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43350-honeywell-touchcenter-change-language/page/2/#findComment-497211 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 20, 20206 yr comment_497213 Yes, Honeywell now post some firmware releases to: https://www.security.honeywell.com/uk/resources/technical-support/software-upgrades/galaxy-software-download-centre No support if you brick your devices though. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43350-honeywell-touchcenter-change-language/page/2/#findComment-497213 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 20, 20206 yr comment_497216 Interesting that they have there firmware on a public FTP. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43350-honeywell-touchcenter-change-language/page/2/#findComment-497216 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
March 20, 20206 yr comment_497218 12 minutes ago, sixwheeledbeast said: Interesting that they have there firmware on a public FTP. They don't care And still no one has bought them ..... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43350-honeywell-touchcenter-change-language/page/2/#findComment-497218 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
