September 9, 20197 yr comment_488577 I have an issue with a Pyronix enforcer alarm kit. The PIR that came is unable to detect in the rear room as there are bifolds and a kitchen which raises the temp too high. I'm looking for a Dual tech PIR and there are 3 available so which is best and easiest to install for a DIY application. FPKX15DT3 ,FPKX15DTAM3, Pyronix Enforcer KX12DT,. cheers Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43109-pir-issues/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 9, 20197 yr comment_488579 So your wiring it? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43109-pir-issues/#findComment-488579 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 9, 20197 yr comment_488580 DT isn't going to solve the issue if it's heat or a door in the way. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43109-pir-issues/#findComment-488580 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 9, 20197 yr Author comment_488582 Hi Its a wireless system. I think its a heat issue only as the glass doors and sun ramp up the hest in the room adding the fact that cooking was going on as well at the time it was very hot in there. worked in the evening when the temp had reduced. no doors or obstacles of any fashion in the way.. Cheers Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43109-pir-issues/#findComment-488582 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 9, 20197 yr comment_488584 Well all those DT's are wired. I don't use Pyronix but wireless DT's are pretty rare, not all manufacturers have them. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43109-pir-issues/#findComment-488584 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 9, 20197 yr comment_488586 3 hours ago, PodMan said: I have an issue with a Pyronix enforcer alarm kit. The PIR that came is unable to detect in the rear room as there are bifolds and a kitchen which raises the temp too high. I'm looking for a Dual tech PIR and there are 3 available so which is best and easiest to install for a DIY application. FPKX15DT3 ,FPKX15DTAM3, Pyronix Enforcer KX12DT,. Get rid pir and use perimeter protection in that area perhaps you maybe 3-4 contacts / shocks depending on how many opening you have Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43109-pir-issues/#findComment-488586 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 9, 20197 yr comment_488595 Wireless dt i only know of hkc. It wakes the mw part up when needed I'd assume texe have one tho? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43109-pir-issues/#findComment-488595 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 9, 20197 yr Author comment_488597 2 hours ago, sixwheeledbeast said: 10 minutes ago, james.wilson said: Wireless dt i only know of hkc. It wakes the mw part up when needed I'd assume texe have one tho? Well all those DT's are wired. I don't use Pyronix but wireless DT's are pretty rare, not all manufacturers have them. Hi again Bought system from SW last week. KX12DQ-WE is wireless has digital temp compensation when room temp matches body temp and the KX12DT is wireless also and is dual tech so which is best. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43109-pir-issues/#findComment-488597 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 9, 20197 yr comment_488603 What's the issue detection in a hot area or false alarms. I would always go for perimeter in a conservatory etc securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43109-pir-issues/#findComment-488603 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 10, 20197 yr Author comment_488614 It’s not a conservatory it’s a heat issue in a large room that is a kitchen/Dining/sitting room with 6m bifolds floor to ceiling. Last Sunday with sun and cooking in the room through the doors the temp rise caused the device not to be able to detect a us moving. No false alarm just did not detect. Pyronix Tech said dual tech or similar. Cheers Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43109-pir-issues/#findComment-488614 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
