Grade 3 with smoke alarms?
They are certainly a big footprint compared with other devices but they tick all the boxes on reliability and functionality.
  • Replies 31
  • Views 6.7k
  • james.wilson
    james.wilson
    Smoke detection in yhis case would be classed as ancillary devices and would not need to be disconnected.  However they are not the same as a 5839 fire alarm. But i have smokes and Co on my own a
  • PeterJames
    PeterJames
    Using all grade 3 kit and installing it to grade 3 is fine but you cant call it grade 3, in the same way as if we installed a grade 3 system and put a grade 2 door contact on it, it then becomes grade
  • james.wilson
    james.wilson
    If a lower graded i&has part is fitted to an i&has then it lowers the overall grade however fitting an unrelated switch to signal something else isn't i&has
Yeah sure just seems a shame the 12v versions are quite literally 3 case design generations behind the current mains ones now.
Edited by datadiffusion
