Gaps in the Security Market
Cound create a central lighting control unit? People interested in that sort of stuff?
I use my hkc panel at home to run my lighting etc.
Retro fitting home automation linked to the ia is one direction I'd like to go
15 minutes ago, al-yeti said:
Change title to gabs in security market
Ha ha just seeing what it takes to get into it... I'm quite an entrepreneurial  person. Just thought because I have knowledge of this industry I might have a better chance of getting going, even something small at first. I could design a quality bell box for example
Edited by Gabs
I think alarms is a declining market, most small manufactures of alarm stuff have gone.
A bell box is plastic moulding & electronics for £20 odd,
A tool box is plastic mounding no electronics & about £20 odd ?
Edited by MrHappy
I know what you mean, a tool box would be a good idea, but I can't just make one and expect to sell it. What is your tool box missing that you could do with? If I can find a problem with a product fix it, I can have a much better chance of someone investing. E.g. Gabs goes to Dragon's Den, he has to convince the savages sat in front of him his product is worth selling, a product the same as 1000s of others on the market. However, if he can show that he has found a problem and fixed it he will more likely get money for a factory and an injection moulding machine... Then MrHappy will buy it because he is happy a problem he identified has been solved. Is there anything that poses a problem in your work-related life you could do with being solved?
Plastic moulding-
A shallow curricular box to mount an eyeball camera on, with 4 flattened sides for conduit entry
A box to screw on the wall behind the telly big enough to take a brick psu & have enough space to terminate shotgun to 12v or cat5 onto coax for the dvr
A plastic conduit box to connect to a RSC like the MK dantech but plaggy
Most eyeball cameras have optional conduit backboxes or rings?
A boxed PSU?
What's up with a normal JB or the Dantech one. Would have to get graded to be useful.
yes, however a Hik one is £10ish & only suitable for for certain products, often has a hole for PG gland, can't be used as an elbow or a t
So plaggy, white or back, round plain lid  make your own fixing holes
38 minutes ago, sixwheeledbeast said:
A boxed PSU?
a 5a one would be quite big behind a telly
in fact make a circuit board to fit in a terminal box
I don't fit Hik so no idea.
Dantech have a wide but very slim one for upto 8 cam jobs
There's also Elmdene Easyfit or other one's that look like a slim IP box as options.
Butcher a normal JB with some cheap plastic mount?
