Risco iwise dt pir
Hi I was wondering if anyone could provide some insight as I have 2 Risco iwise pirs that I tried to set up to use the greenline thing ie to disable the microwave when unset but I’m wondering if it’s a Risco panel Riscobus only (in this case I’m using a galaxy panel) feature as one of the pirs is now flashing the red led occasionally with a solid green led does anyone know what this means.
thanks
thanks
What you on aboute dude?
When unset y u need microwave deactivated?
Red alarm
Yellow PIR
Green part of microwave
Edited by al-yeti
Frys your brain innit
As above its not a worry, but if that concerned don't use them at all. But if you have them there is an input to disable the microwave. It's a popular Israeli detector
Yes they are set up to have microwave disabled when unset but I have a constant flashing red light which the installation Manual says is a communication error but that didn’t make sense hence me wondering if it’s a Risco only feature I also get a solid green light with the flashing red occasionally I don’t mean the detection led I know in normal operation what the leds mean but it’s just on constantly for hours and then goes out sometimes.
the flashing red goes away after removing power.
I'd say it's a sensor issue what if you don't use the disable mic option?
If this is a domestic install you dont need Dtecs at all DT's are for hostile areas like garages, factories ect. I would never install a dt in a house unless I had to for confirmation purposes, they're not designed for that environment
