Accenta 7 quick power cut alarm/then no status lights?
  • Replies 79
  • Views 22.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • cynical & embittered is the TSI default outlook
  • sixwheeledbeast
    sixwheeledbeast
    I still say a good, well maintained, fit for purpose system wouldn't need ripping out. People are too quick to add to the E-waste pile IMO. It's easy to say you swap your car or phone more regula
  • Specialist
    Specialist
    That goes for old alarm engineers too mate  (Not that I'm saying Your old, you understand)
34 minutes ago, sixwheeledbeast said:
20 minutes if BS, 15 minutes if EN
Yeah mate, I know. For some reason I thought the OP said it wasn't that old, can't be bothered to go back and read it all again.
Life's way too short ;)
Edited by Specialist
Qfa
3 hours ago, Specialist said:
 Did he take a meter up into the attic to check charging voltage / current ?.
If he didnt then I would advise that you turn the power off in a month or so's time to see if the battery is still charged
Agreed, it's surprising how many don't take the extra little bit of time to do it. Don't know if they've never been taught the importance of testing or are just too lazy to be honest.
3 hours ago, james.wilson said:
Qfa = quoted for agreement
Hi James, Sorry buddy:  Yes I know what it means, I was just wondering why you were asking.
13 hours ago, Specialist said:
Hi Jez: Yes, from what you've said then it's quite feasible for you to change the battery yourself in the future. Did he take a meter up into the attic to check charging voltage / current ?.
Sorry: Not sure what you mean by even worse case scenario, bell only sounds for 20 minutes on the Accenta 6 ?. That's more than enough time to deter a burglar and really annoy your neighbours.
I'm sorry i'm not sure :s
He didn't turn the mains power off though, but must have opened the CPU box, or would he have taken the fuse out which sits alongside the box?
This set the alarm off, i put my code in, he took old batter out and new one in?
Then did a walk test and checked all the sensors etc, mentioned how he had repacked a previous failed sensor a few years ago when the previous occupant was there.
The reason i was asking about how long the alarm goes off for, was worse case scenario i set the alarm off and cannot turn it off, it doesn't just go off forever....!
Edited by jezthomp
Hi Jez: No it shouldn't continue running, it should cut off once the 20 minutes timer is up.
He would have changed the battery with the panel still powered from the mains, it's something most engineers are taught to do.
The battery charge voltage and current should have been checked to ensure that the charge circuit is functioning correctly and that the faulty battery hadn't damaged the circuit.
